by gberry78
Go Further Roaming Add-on
If I change to a SIM only plan can I still get the Go Further Roaming Add-on to use in the USA?
9 REPLIES 9
by Ace Contributor
Re: Go Further Roaming Add-on
Hi @gberry78 Yes, only sim access plans are ineligible.
Hi @gberry78,
Thanks for joining the EE Community.
That's a great answer from @chistery
If you need any further information, please see Go Further Roaming Add-on.
by gberry78
Thanks Chistery
Only SIM Access is mentioned as being excluded but it doesn't say "Only Sim Access is ineligable".
It is unclear from that article whether SIM-Only in general, 30 day SIM-Only or even PAYG are eligible.
Would you say from its lack of being mentioned that even PAYG can buy GO Further? I wouldn't have thought that was EE's intention.
Hi @XRaySpeX.
It isn't available for pay as you go.
I've asked for that to be clarified and updated on the Go Further page.
Chris 🙂
Thank you, @Christopher_G. As I thought.
Most add-on/extras has a section "Who can get this?" spelling out just who can or can't.
by Ace Contributor
The T&Cs do say its only available on pay monthly plans, which does suggest it might apply to 30 day pay monthly plans too, though not sure how they enforce the minimum term.
Go Further Add-on
Available with pay monthly EE SIM plans
@chistery: Where? Where to you find T&Cs for Go Further? The help article  Go Further Roaming Add-on doesn't refer to them. I was looking for them everywhere to resolve this point.
by Ace Contributor
@XRaySpeX this is where I found it
