Highlighted
by Profile closed
Not applicable
Global Roaming Minutes add-on on a mixed EU+non-EU trip
Hi
If I had an active Global Roaming Minutes add-on and was in an EU country making calls to UK as well as receiving calls, would my add-on minutes stay unused, or get used before the EU Roaming allowances?
Highlighted
Solution
Re: Global Roaming Minutes add-on on a mixed EU+non-EU trip
Your Global Roaming Minutes will not be used whilst you are in EU. You'll be using your UK allowances.
Highlighted
Solution
Highlighted
by Profile closed
Not applicable
@XRaySpeX this was my first thought as it would be logical.
However, the list of roaming zones covered by this add-on includes (I believe) EU as well. Hence the confusion.
Highlighted
Hi @Profile closed,
@XRaySpeX is correct, you'll be using your UK allowances in the EU.
Highlighted
by Profile closed
Not applicable
@James_B thanks for confirming that
Highlighted
No problem @Profile closed Smiley Happy
Recent solutions
