by Miket2001
Gifted data for roaming
i have a max plan and a separate  sim only plan for my daughter to use. I gift her 15 gb of data each month. We are travelling to the USA this month and I was planning to get her the roaming add on for a flat fee of £10 per month.  Can the gifted data be used with the roam further add on or will it be limited to the contracted amount of 250mb? I have looked on line and can’t seem to see an answer to that specific question. Thanks in advance.
Mike.
Re: Gifted data for roaming
Yes, she may use the gifted data from you + her contracted data as long as it does not exceed 15 GB pm.
You sure the contracted amount is 250 MB? Seems a bit low.
by Miket2001
Thank you for the info, I was hoping that would be the case.
It is definitely only 250mb - as that was the cheapest sim only contract at the time.
Thanks again,
Mike.
Thanks! You're welcome 🙂 ! Glad I could be of assistance.
