by Roger47 Investigator
Germany: Mobile data: fine. Incoming: fine. Call German; fine. Can't call UK
In Germany.  As mentioned in Subject, all is well except can't call UK mobiles or landlines.  Goes straight to a tone.
Re: Germany: Mobile data: fine. Incoming: fine. Call German; fine. Can't cal
Hi @Roger47
Have you made sure international calls are activated?
Log into your on line account and then Menu - Manage Device - make sure you have activated roaming and international calls.
Or
From the MyEE app Current Usage - Controls - activate use phone abroad and make international and premium calls
Thanks. Yes seems like the problem: "call abroad and premium rate" "blocked" !!! And can't find a way to unblock it myself.  So any more help greatly appreciated !!!
Hi @Roger47
If you cannot unblock this service as per my instructions above then you will need to speak to CS as you might need to pay a deposit. You can contact them on another device/land line, via live chat in your on line account or on EE get in touch page.
Thank,
Thanks - will contact CS. It's all very strange cos I have two numbers on the same account and the other is fine !
