by eValery
New Member
Free EU Roaming
Is the free EU roaming applied to all customers or just customers with the 4GEE Max Plan?
Also, as a pay monthly contract customer, how would I set this up?
by Ace Contributor
Solution
Re: Free EU Roaming
HI,
@eValery
Free EU roaming applied on all ee customers it does not matter if you have max plan, normal plan or pay as you go.
But as might you know in new max plan (after 10th May ) you can roam free in Australia, Canada, Mexico, New Zealand, USA.
You just need to send text Roaming to 150 before travelling to setup your roaming.
Many Thanks
by Ace Contributor
Solution
Re: Free EU Roaming
HI,
@eValery
Many Thanks
Re: Free EU Roaming
Hello @eValery
Thanks for coming here.
If you give us a call before you go we can make sure Roaming is set up and remove any International bar for you.
Hope you have a great time 🙂
