by kkoolett
Extra data roaming in usa
Can I buy roaming data for specific days in advance? Or is it something I need to switch on and off? Or I switch it on now and will be only billed when I'm actually in the US and switch my roaming on, and then it stops when I leave the country or I turn off my roaming while there?
Re: Extra data roaming in usa
Hi @kkoolett
Roaming (if activated) is automatic.
You cannot buy data in advance.
What plan are you on as some have US roaming benefits.
by kkoolett
Hi, thanks for your reply. I'm only on the Essential plan.
So do you mean I can upgrade my plan now and then when roaming is on
they'll start charging me daily? And then when I switch roaming off they
stop the daily charges?
Thanks for your help.
Hi @kkoolett,
With the Travel Data Pass you'll only pay for the days that you use data in your destination, so if you don’t use any, you won’t pay a penny.
And don’t worry about using too much data – if you use up your daily limit, we’ll let you know so you don’t get any unexpected bills.
You can also add more data (at the same price) to see you through the rest of the day (up until midnight UK-time).
There’s no need to remove Travel Data Pass when you return to the UK, just keep it in the background for the next time you travel, but if you want to opt out at any time, simply text STOP TRAVEL to 150 and revert back to our standard data add-ons.
