by AmberEB
New Member
Error 10
I can't send text messages abroad; it comes up as an 'error 10' and won't send - I am using a personal account
Re: Error 10
Hi @AmberEB
Log into your online account and then menu - Manage device, make sure you have activated roaming and international calls.
Or
From the MyEE app current usage - controls, activate use phone abroad and make international and premium calls
Re: Error 10
Hi @AmberEB
Welcome to the community. 🙂
If everything that @Northerner mentioned is all already set up, or if it still isn't working after, please try manually selecting a different available network:
Device type Actions
iPhone Settings > Mobile Data > Network Selection > Turn off Automatic
Android Settings > More Networks > Mobile Networks > Network Operators > Tap OK
Windows Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Let us know how you're getting on.
Re: Error 10
For sending texts, check your phone has the Message Centre no. setting for EE as +447958879879.
