by Daleoneil Investigator
Enable roaming
Please could a member of staff enable my data roaming, mobile number is ********** thankyou
[MOD EDIT: Please do not post personal details onto the public forum]
Please could a member of staff enable my data roaming so I can make calls EU
Please can someone enable my data roaming, mobile number is ********** thankyou
EE Employee
Re: Enable roaming
Hi and welcome to the community @Daleoneil
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
Please also can I get you to try and dial a friend or family member using format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
Re: Enable roaming
Thanks for your help, my 4g is back on so that will do for now.
Re: Enable roaming
Excellent @Daleoneil 🙂
Give us a shout if you need anything.
Enjoy the rest of your trip.
Chris 🙂
