by Melissac
New Member
Egypt roaming
does the my WiFi box cover Egypt? I’m travelling to hurghada next week and I have both a monthly plan and a my WiFi box.
Thank you
Re: Egypt roaming
Hi @Melissac
It may not work because those devices are designed for the UK and EU.
Additionally you are outside the EU so you will need to text ROAMING to 150 to ensure your device is set up.
Lastly roaming costs and add-ons for Egypt can be found here.
