by Ollie2222 Contributor
EU roaming on business tariffs
I'm just looking at the business SIM only deals you have at the moment http://business.ee.co.uk/business-deals/simonly
The cheaper tariff with 8gb of data doesn't include EU data roaming.
Am I correct in thinking that all plans including this one will get EU data roaming included from June 15th when the new EU rules come into effect?
by Brilliant Contributor
Solution
Re: EU roaming on business tariffs
@Ollie2222 Hi Yes you are correct and it will include it from the 15th of June
6 REPLIES 6
Solution
Thank you for the very quick reply Damien, just a couple more queries if you can help.
Could you just confirm the roaming includes calls, texts and data?
Are there any restrictions on the data use, eg. maximum amount per day etc, or could all of the data up to the 8gb tariff limit be used in the EU if needed?
Can I also check that the UK and EU data usage allows tethering too?
Hi @Ollie2222 no worries Smiley Happy
yep the roaming includes all calls texts and data.
There is a fair usage policy of 15gb per month in the Eu but that won't worry you as the plan has 8 so yes you can use all of it there is no limit per day etc you could use it all in one day if you wanted to.
Yes therthering is included.
Those are exactly the answers I was hoping for.
Thank you for the very prompt responses, much appreciated.
@Ollie2222 Your most welcome come back anytime if you need anything else
EE Employee
Hi and welcome to the Community @Ollie2222
Glad you found the information that was given by @Damienw1 useful.
Many thanks,
Lee
