by AGBell Valued Contributor
Valued Contributor
EU data roaming and tethering
I think I know I can use 15GB of data when in the EU but can I use some of that to tether my iPad or laptop?
Also, I don't understand the different 4GEE plans or which I'm on to find out if I'll get slow or fast data abroad. How do I find out?
Re: EU data roaming and tethering
@AGBell   Yes you can tether.  Look at your online account /my EE app it will say there what type of tariff you have.
Valued Contributor
Plan just says EE SIM only, no mention of 4GTHIS or 4GTHAT.
Hi @AGBell,
Welcome to the EE Community.
As you are not on a Max Plan, you will get our standard roaming speed abroad - fast enough for streaming video, uploading photos and browsing.
4GEE Max customers get our fastest available speeds at home and abroad. But please note: maximum speeds will be dependent on the local network and may not be as fast as at home.
Valued Contributor
Thanks. What speed do I get in the UK and what is the standard roaming speed when in the EU?
I'm finding all the 4GEE PLANS confusing and more so because I have no idea what plan I'm on. Where can I look to find out all the details?
Hi @AGBell,
Your roaming speeds will depend on a number of factors, including your location and the local network you are connected to.
You'll get up to 60Mbps in the UK.
