by MMayers
EU Roaming
With the Recent changes that occured on the 15th June, Roaming in the EU is now free but do i still need to activate anything for this?
by Profile closed
Not applicable
Solution
Re: EU Roaming
@MMayers Yes, if you have never roamed before with EE, you just need to make sure romaing is enabled on your account before you travel.
Easiest way is to call CS and ask them the enable roaming for you.  I beleive you can now also send a free text to 150 with the phrase ROAMING as well now.
by Profile closed
Not applicable
Solution
Re: EU Roaming
Re: EU Roaming
Thanks for helping @Profile closed
Please do make sure this is set up before you go if you have a pay monthly account @MMayers.
If you are on pay as you go this will be set up for you already 🙂
Have a great time!
