by esc20
New Member
EU Roaming on Everyday Plan
Hello,
I have the Everyday Plan and my calls cost 40 p/min and it seems I was charged like that when I called yesterday from Portugal to a Portuguese number.
However I received the welcome text saying that "UK rates apply - calls cost 4.4 p/min". Which is correct? Is the 4.4 p rate applicable to someone without Smart Packs or Call Boosters?
Thank you
Re: EU Roaming on Everyday Plan
Looks like the welcome msgs are out of date. Those are the old rates before the new EU roaming came in. @Lee_H?
The new higher rates are intended to be applied only after you have run out of your UK allowances, which would be free in EU.
However, for those users who only rely on normal PAYG on a per unit basis & do not buy packs, these new rates come as a kick in teeth. The new EU roaming rules have not worked out well for them :(.
by Profile closed
Not applicable
Hello @esc20 the text message you received is for the old roaming rates from before 15th June. From 15th June onwards using your phone abroad in the EU and EEA now costs the same as using your phone in the UK:
http://shop.ee.co.uk/international/travelling-abroad
EE Employee
Hi @esc20 and welcome to the community.
Please let me look into this for you, I have sent you a Private Message to gain some details.
Many thanks,
Lee
