by autarky15 Contributor
EE routes roaming data through the U.K.
When I was in Europe my data was automatically being routed back to the UK (had a UK ip address) with no VPN turned on. Does anyone know how if EE can disable this?
by Profile closed
Not applicable
Re: EE routes roaming data through the U.K.
I don't think you can sorry, as that's how the EE roaming platform works with everything routing via the UK.
It's designed that way so EE can control data usage whilst customers are roaming to prevent bill shock when roaming outside the EU.
Okay thank you
