by Armando172 Investigator
EE data stopped working while abroad all of a sudden even though I am connected
My Ee data stopped working all off a sudden yesterday even though I still have data and I am connect to 4G with roaming on I cannot even access http://add-on.ee.co.uk
7 REPLIES 7
Re: EE data stopped working while abroad all of a sudden even though I am connec
Hi @Armando172,
Welcome to the EE Community.
Are you still able to make calls or send texts?
Are you in the EU?
Yes I can make calls and text without an issue I have also already reset my network settings
Hi @Armando172,
Have you tried selecting a different network manually?
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
I have I even contacted EE and they said there is no reason why my data shouldn’t work
Hi @Armando172,
Is mobile data roaming enabled in your phone's settings?
Have you tried turning off 4G to see if your phone can connect over 3G?
Yes I have tried this still doesn’t work contacted ee they resetted settings on their end however still not working
EE Employee
Hi @Armando172
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
iPhone: Go to Settings > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Android: Open the Settings menu >Tap More > Mobile Networks > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
