by HannahSpanner
EE coverage in Nepal
After a few phonecalls to EE (from someone else's phone!) I've discovered that my EE sim card is not currently working in Nepal, because of some issues with the agreement with NTC. My EE simcard used to work fine when it connected to the NCELL network in Nepal. This has been an issue now for a few months. Do EE know when they will sort out their agreement with NTC (or go back to NCELL?) so EE customers will be able to use their sim cards in Nepal once again?
Re: EE coverage in Nepal
Hi @HannahSpanner
Welcome to the community.
Are they the only 2 networks that are available when you do a manual network search?
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Look forward to hearing from you.
by HannahSpanner
Thanks very much - this has fixed it! It wouldn't allow me to manually connect to the NCELL network (it said I should try again later) but did allow me to connect to NTC, and now my simcard appears to me working. Thanks again!
Awesome, thanks for letting me know @HannahSpanner. 😄
Enjoy the rest of your time in Nepal.
Chris 🙂
