by Awisbey Contributor
EE/USA Fair Usage
Hi Is there a way to see how much of the 15GB I've used of the FUP whilst abroad. I only see the total data. I know normally I could just check at the start/end but I've others back in the UK using it on a sharer plan as well. Regards Andy
EE Employee
Re: EE/USA Fair Usage
Hi @Wisbey and welcome to the community.
What is displayed when you pop over to http://add-on.ee.co.uk/status?
Many  thanks,
Lee
I just see the total data used and available
EE Employee
Hi @Awisbey
Please let me look further into this for you.
Many thanks,
Lee
