by mastersjr
New Member
EE Max Plan in the US
Can someone please confirm whether both the following types of calls are covered by the EE Max Plan when made while roaming in the US:
  1. Calls made to US mobile or fixed numbers
  2. Calls made to UK mobile or fixed numbers
Note: I have texted ROAMING to 150 to ensure roaming is activated.
Many thanks
John
by Scholarly Contributor
Solution
Re: EE Max Plan in the US
Both are covered if you have a Max Plan that started on or after 10 May 2017.
Solution
by Ace Contributor
3: Calls and texts made to EU and other max plan countries are also included on the new max plan
