Highlighted
by Contributor
EE Hawk in Sardinia
My EE  Hawk doesn't work in Sardinia not even in Olbia international airport. It worked fine in Dubai. Myself and many others have tried all the settings without success. Does it need activating for Sardinia? Please help as I need to use the phone. Thanks.
12 REPLIES 12
Highlighted
Re: EE Hawk in Sardinia
If it worked in Dubai it should work in EU. Does it work in any way? Can you receive calls & texts? Can you phone local nos. but not UK? Does data work?
Highlighted
by Contributor
None of these work. The message says mobile network not available. Also is
there any alternative way I can get to my voicemail?
Highlighted
Hi @PatrickH
Are you PAYG or pay monthly contract?
When did you last name a chargeable call or text?
When was the last time your phone/tariff connected to the UK network?
Highlighted
by Contributor
Thanks, monthly so no chargeable. Last connected 18 may just before left uk.
Highlighted
Hi @PatrickH
You have checked in your EE app that roaming is activated?
Also can you check locally on your phone under settings - network (or similar) and see if there is a roaming option, and it's active.
Highlighted
It was in Dubai, so why wouldn't it be in Sardinia?
Highlighted
by Contributor
Thanks, roaming is switched on in settings.  Could it be that roaming in Sardinia using the EE Hawk needs additional activating by EE itself?
Highlighted
It shouldn't do. In fact it should be simpler as it is within the EU & therefore uses your UK allowances while Dubai doesn't.
Highlighted
@XRaySpeX @PatrickH
It shouldn't need checking, but it's worth just checking, just in case.
Highlighted
Hi @PatrickH,
Welcome to the EE Community.
Have you tried manually selecting a network in your mobile network settings?
Highlighted
by Contributor
Thanks James, yes I have tried manual but with no success.
Highlighted
Thanks for confirming @PatrickH
I would recommend getting in touch with our technical care team regarding this. They will also be able to ensure everything is how it should be on your EE account.
Please keep us updated,
Katie 🙂
