by Mr111 Established Contributor
Dubai options calls/texts/data
On a 4G max plan pay monthly. Looks like can't use roaming for calls/texts/data when in UAE.
So what are options please? Get a data and a call/text add on total £12 per day?
Is there any other options? New SIM card or anything when there? Anyone done this or help please?
Solution
Re: Dubai options calls/texts/data
Hi @Mr111
If you are staying for some time, then I would use a local SIM. Your phone will need to be unlocked
Otherwise you have the add-on options you have already seen from the EE UAE roaming page
Lastly, if you do use your EE sim then make sure roaming is activated by texting ROAMING to 150.
Solution
Hi @Mr111
Yeh phone is unlocked and roaming works. But to hand data and calls/txts would be £12 a day on EE.
Where do you get local SIMs from when there and how much are they.
