by rbs_gb Investigator
Does wifi calling count as roaming?
I'm off to the Canary Islands for five months and expect to fall foul of the stable link test. #my question is after the two months grace period is up, if I use WiFi calling to make calls, will that still count as a roaming call and be charged?
Ray
Solution
Re: Does wifi calling count as roaming?
Hi @rbs_gb
WiFi calling doesn't work outside the UK.
Solution
Hi @rbs_gb
Thanks for the quick answer. Moves that option off my list then!
