by Frogzpawn Investigator
Does the galaxy note 4 sm-n910f work in the USA?
And do I need to change any settings if it does?
by Profile closed
Not applicable
Solution
Re: Does the galaxy note 4 sm-n910f work in the USA?
Hello @Frogzpawn the Galaxy Note 4 is a quad band phone and should work in the USA yes. You should receive a text when you first switch your phone on letting you know charges for your destination and how to buy roaming add ons.
If you are a pay monthly customer you will need to check roaming is enabled on your account before you leave by texting the code RO to 150 even if you have a plan with roaming allowances included. More information on roaming can be found using this link. :):
http://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-using-your-phone-abroad...
6 REPLIES 6
by Profile closed
Not applicable
Solution
That's good news, thanks.  So does the apn
Try that again! Do the app settings need changing?
by Brilliant Contributor
@Frogzpawn App settings? No nothing should need changing
Darned autocorrect! Should've read apn settings
by Profile closed
Not applicable
Hello @Frogzpawn your default EE APN settings should work as normal and you should not have to change these when roaming no. 🙂
