by JoyceBols Investigator
Does EU roaming cover North Cyprus?
Can you please confirm whether the EU data roaming covers North Cyprus? I’ve read that Cyprus is covered, but I’ve also read that North Cyprus is considered part of Turkey, which is not covered.
Thank you
Re: Does EU roaming cover North Cyprus?
@JoyceBols   when you’re in Northern Cyprus you might connect to a Turkish network operator you are not covered for this you have to make sure you’re connected to a Cypriot network to not get roaming charges.
Sent from my iPhone
Thank you Chris.
Is there a way to prevent a connection with Turkish networks from happening automatically?
Hi @JoyceBols,
Only Turkish mobile networks operate in Northern Cyprus so there isn't the option to connect to a Cypriot network.
You can check the costs for using your phone in Northern Cyprus here.
