by Profile closed
Not applicable
Does EE provide a way of tracking used Travel Data Pass allowance?
I am in one of the Travel Data Pass destinations, but no idea where to look for used/remaining daily data quotas. Nothing in the app.
Am I not seeing something by looking straight at it?
by Brilliant Contributor
Solution
Re: Does EE provide a way of tracking used Travel Data Pass allowance?
Hello @Profile closed
Thank you for taking the time to post today. Smiley Happy
The MyEE App should show you your remaining roaming allowance. If the app isn't for any reason, you can check your roaming allowance by browsing add-on.ee.co.uk. You can also view your last five data allowances.
Solution
by Profile closed
Not applicable
@Inyourbox thanks, the add-on.ee.co.uk link did the job. App just shows "data allowance" add--on that ends in 15 hrs without telling niether total nor remaining allowance - not fit for purpose.
EE Employee
Hi @Profile closed and welcome back to the community.
I'm glad you have managed to use the add-on.ee.co.uk to find the information you need.
Many thanks,
Lee
by Profile closed
Not applicable
@Lee_H any chance of improving the myEE app accordingly? Thanks.
Great suggestions, @Profile closed.
I'll feed that back to our My EE team.
Enjoy the rest of your trip. 🙂
