by Dinkerbell90
Do we still get charged for making calls FROM the UK to Europe?
So I was under the impression, that if we are in the EU you can make calls etc to the UK and other parts of the EU at no extra cost... is this the same for making calls from the UK to Europe?
by Ace Contributor
Solution
Re: Do we still get charged for making calls FROM the UK to Europe?
Yes you are charged for calling any none UK number when in the UK.
When you are out of the UK however. These calls are then included in the free EE EU roaming:
https://shop.ee.co.uk/international/travelling-abroad
6 REPLIES 6
by Ace Contributor
Hello @Dinkerbell90 calling abroad from the UK is different to roaming and is chargeable:
http://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/calling-abroad-from-the-uk
To add the free call abroad add on giving cheaper rates text the code CALL ABROAD to 150:
http://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/free-call-abroad-from-the-uk-ad...
@Dinkerbell90  You can do not call UK mobiles that are abroad with out any charge to yourself.
EE Employee
Hi @Dinkerbell90 and welcome to the community.
Hope you find the above information to be of great help.
Many thanks,
Lee
by Dinkerbell90
What about if it is to an EU number? Do we get charged for that as well?
If you call a NON-UK no. from UK you will be charged. That's not roaming. From UK you may call a UK no. wherever it is on the world & it will be same as if it were still in UK, often free in your allowances.
by Ace Contributor
Solution
