by Gallowaysabrina
New Member
Do i get charged more while on holiday in europe
by Star Contributor
Star Contributor
Re: Do i get charged more while on holiday in europe
Hello and welcome to the EE community.
No, you have your inclusive allowances within the European roaming zone apart from on certain plans with a large amount of data where there is a 15GB roaming data cap.
Good Morning @Gallowaysabrina
Welcome to the community.
You can use your plan allowances in 48 EU/EEA destinations which includes minutes, texts and up to 15GB of data allowances.
Before you go if you're on a pay monthly plan text ROAMING to 150 to make sure you are all set up for roaming.
If you're pay as you go you will be automatically set up to use your phone abroad.
For full information see our EE Roaming getting ready to use your phone abroad.
Thanks, Leanne 🙂
