by Ang11x Investigator
Do I turn data roaming on to use my plan abroad
To use data that's  included in my plan abroad do I need to turn data roaming on ?
by Profile closed
Not applicable
Solution
Re: Do I turn data roaming on to use my plan abroad
Hello @Ang11x yes data roaming in Spain is included in your UK monthly allowance:
https://shop.ee.co.uk/international/travelling-abroad
6 REPLIES 6
by Profile closed
Not applicable
Hello @Ang11x yes data roaming needs to be enabled on your device to use data abroad. 🙂
Thanks Tom
just to clarify , if I turn data roaming on I won't get charged as it will use my 10 gb allowance from my plan ?
by Profile closed
Not applicable
Hello @Ang11x where are you traveling to?
You can only use data abroad with an eligible allowance or add on the same as in the UK. EE do not charge on a pay per basis for data no. 🙂
I'm in Spain on holiday and I have 15 gb data in my plan but  worried if I turn my data roaming on I'll get massive charges ...
by Profile closed
Not applicable
Solution
Hi @Ang11x
Does this answer all your questions?
I can see @Profile closed has given some great help here to you.
Cheers
Richard
