by Mrhector68
Do I need to turn on roaming to use my travel data pass
Do I need to to turn on data roaming to use a data travel pass?
by Mrhector68
by Ace Contributor
Re: Do I need to turn on roaming to use my travel data pass
Text Roaming to 150. Before travel.
Many Thanks
EE Employee
Good Morning @Mrhector68
Thanks for joining the Community! Smiley Happy
You will also need to turn Data Roaming on on your phone.
What phone are you using?
Thanks - Karen. Smiley Happy
by Mrhector68
iPhone 6s EE customer services said keep usual data settings, you think I need roaming on?
Nick
Sent from my iPhone
EE Employee
Thanks for getting back to me @Mrhector68
It is normally on as defult but you can double check in:
  • Settings
  • Mobile Data Options
  • Data Roaming - needs toggled ON
Hope this helps!
