by GpaM Investigator
Do I need to turn on Mobile Data to use my GoFurther add on?
Re: Do I need to turn on Mobile Data to use my GoFurther add on?
Only if you want to use data. Also Data Roaming ON.
Thanks for that. I just want to be sure I won’t incur any charges by turning on Mobile Data while I’m here in Mexico.
GpaM
Sent from my iPhone
Hello there @GpaM
Welcome to the community.
You can use your minutes, texts and up to 15GB of data with our Roam Further Pass.
If you run out of data in Mexico, you will be able to purchase a data add-on.
When you switch your device on abroad, we'll send you a text message with full details on how to purchase a data add-on.
You won't get extra charges for data unless you purchase a data add-on.
Have an amazing time 🙂
Do I turn on data roaming? I am concerned that I may then be charged.
GpaM
Sent from my iPhone
Hi @GpaM
Yes, to use data in Mexico you will need to activate this.
If you have the Roam Further pass you can use up to 15GB of your data allowance.
No charges will be applied for data unless you buy an extra data add-on if you use the 15GB 🙂
Recent solutions
