by KyleSofia
New Member
Do I need to change anything with my phone if travelling to spain
Solution
Re: Do I need to change anything with my phone if travelling to spain
@KyleSofia : No, it is part of EU. You may use your usual allowances there with up to 15 GB data per billing month if you have more.
If you are on contract, remember to text ROAMING to 150 before you leave to check roaming is enabled on your account.
Solution
