by AT64 Investigator
Do I have free data roaming with my plus package for NZ
Hi, please help. I have the plus package so I can use my phone in NZ. When away from hotel my phone needs data roaming to work properly. Is this included in the package or will I get huge bills when I get home if I use it?
Solution
Re: Do I have free data roaming with my plus package for NZ
Thank you so much. You have put my mind at rest. I will check my usage on the app.
So kind of you to take the time to help the tech under achievers.
I can enjoy my holiday with no worries now.
8 REPLIES 8
Hi @AT64
If you have an EE Max plan taken out after the 10/05/17 then roaming in NZ is included, so no charge.
If not then you will need an add-on
Have max plan, in NZ do I turn on data roaming and will I be charged extra?
If I turn on data roaming on my phone is it covered by the max plan in New Zealand?
Thank you. Does that mean I can switch on the data roaming and will not pay if I stay under my 8mb limit? Sorry I'm a bit thick at all this!
Sent from my Samsung Galaxy smartphone.
by Ace Contributor
@AT64 Did EE send you a welcome text? That usually tells you if you can use your data as part of your plan?
E.g.
Yes they did. I just wasn't sure about turning on the data roaming button as you hear such horrendous stories of the cost when you get home. I know I have data but is that the data roaming button?
I do feel quite thick about this.
by Ace Contributor
Hi @AT64 Yes, it's the data roaming button. If you were sent a text saying data is included, and you're on a max plan, you can turn on data roaming and not face additional costs for data.
Also, with EE you can't just get charged for data. If you didn't have a max plan or a data add-on, you would just be redirected to a page to buy an add-on, so you cannot face unknown costs.
I do tend to check my unbilled usage when abroad every now and then just to make sure it looks ok though.
Solution
Good Morning @AT64.
New Zealand sounds great, funnily enough, I had a kiwifruit for breakfast! 😉
I'm glad you got the help you needed in the community today.
I hope you enjoy the rest of your holiday 🙂
Jon
