by Zaheenmulla1234
Data
 Will I be able to use my data in Turkey Istanbul for free or will there be a charge
by Ace Contributor
Solution
Re: Data
HI,
@Zaheenmulla1234
It will be a charge. Turkey is not include in Europe Roaming.
http://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/turkey-...
Details can find above link.
Many Thanks
by Profile closed
Not applicable
Re: Data
Unfortunately not sorry.  You will have to buy an add-on to use data in Turkey.
by Ace Contributor
Solution
Re: Data
HI,
@Zaheenmulla1234
Many Thanks
by Ace Contributor
Re: Data
Hi @Zaheenmulla1234. Vodafone are the only UK network to include Turkey in their free roaming package.
