by bmsw Contributor
Data usage not decreasing
My data usage is not decreasing, yet data has been used. Every link i've tried, e.g checking add on status etc , texting AL to 150 has showed no change. I am abroad and roaming, but in one of the countries that allows roaming data to be included in the pack (Switzerland).
P.s The only slight data change I have found is 2MB used of my 'Getting started' pack (no idea where that came from, I didn't buy it). However I have used way more (roughly 1.5MB) and nothing shows this.
13 REPLIES 13
by Ace Contributor
Re: Data usage not decreasing
Hello,
@bmsw Please try this link to check your data usage http://add-on.ee.co.uk/status
please use this link on your mobile data not on wifi,
Hi @bmsw,
Welcome to the EE Community.
There can be a delay in updating your allowances when using your phone abroad.
It should correct itself soon.
by bmsw Contributor
Hi James,
It hasn't updated in over a week, so if this is a lag it is quite a long one, and I want to know how much I've used so I can know if I need to be frugal with my data!
by bmsw Contributor
I've already tried this link, it still showed I hadn't used any of my pack data.
You sure you are not connecting to WiFi, either in hotel or cafes. That doesn't use your mobile data.
by bmsw Contributor
I'm sure, there is literally no wifi where I am, nothing to connect to even if I wanted to!
Hi @bmsw,
How much data does your phone report you have used in the settings?
by bmsw Contributor
2.1GB since the last time I reset it (9 August). But I used a bit of before then (and forgot to reset it before I did, so I don't know how much I've used abroad overall)
Hi @bmsw,
Please get in touch with customer services so we can take a quick look at your account.
by bmsw Contributor
I tried calling them, but it said I had to pay 25p per minute and I don't want to pay for them to correct a mistake in their system!
Hi @bmsw,
Calls to pay as you go customer services are a one off charge of 25p, rather than per minute.
by bmsw Contributor
I called them, they continued to insist I hadn't used any data even though I have. Their system showed no data had been used. Anyone else had this happen?
Hi @bmsw,
It cold be an issue with the local network.
I'm very sorry for the inconvenience and I hope it's resolved soon.
