by ajt22 Investigator
Data usage abroad
Hi all,
I have a few issues regarding data usage in Europe so I'll ask the 'easier' question first.
I got a text to say my data plan could be used abroad from the 15th June 2017. This didn't work. Can anyone confirm what time on the 15th that service would have been activated? Also, is Malta included? Did any settings need changing on my phone? Roaming was on, and texting 'roaming' to 150 confirmed this was running. In short, why didn't it work?
Thanks.
12 REPLIES 12
Re: Why do EE mislead customers about Roaming??
I believe I've also been mislead re: data in Europe. I'm actually in the forums now to gather further information before taking the matter further (this is when I saw your post).
@ajt22: How have you been mislead?
Re: Data usage abroad
Malta is included. It's in the EU.
Any ideas why it didn't work then?
Without wishing to takeover this thread, it looks like yes. This is actually part two of my problem. Knowing European data went live on the 15th, I contact EE on webchat to ask about getting data a week prior to the 15th. I was told this was possible, and I'd have to change my account to give included data. It was a £1 extra per month and I could revert to my initial contract on my return. Throughout my trip, data was never available (be it before the 15th, or on the 15th when I returned home).
EE Employee
Hi @ajt22 and welcome to the community.
So I can try and assist, were you able to use calls and texts whilst there?
Many thanks,
Lee
Yes, calls and texts were fine.
EE Employee
Hi @ajt22
Are you able to currently use data back in the UK without being connected to WIFI?
What device are you currently using?
Many thanks,
Lee
Yes, it's working as expected back in Uk. Phone is OnePlus running Android. I've just been looking through the FAQ's, and I didn't switch off 4G but that shouldn't affect it. I'd expect it to connect at fastest speed available in the area?
EE Employee
Hi @ajt22
Please double check your roaming network options in your menu and double check it is turned on
See below:
Menu Example
If your calls and texts were working it sounds like it could of been a device issue or local network issue.
Many thanks,
Lee
Thanks for your help. All my settings appear to be correct. I will try back next time I'm out of the country.
EE Employee
Hi @ajt22
Please let me know how you get on when abroad next.
Many thanks,
Lee
