by Eazye
Data roaming
Can I use my data in Alicante? And is it in with my usual bill or will I be charged extra?
by Eazye
Data
by Ace Contributor
Re: Data
You can use your UK allowance in Spain, with no extra charge.
W
Re: Data roaming
@Eazye  Yes you can use your data allowance in Spain.   Just text ROAMING to 150 so roaming is enabled on your account.
You can can also use your call and text allowance as well.
Re: Data
Yes, but your data will be limited to 15 GB / month (Far Use Policy).
Re: Data roaming
Hello there @Eazye
Hope you have a great time 🙂
Full EU Roaming information can be found on our help page>
Please do give us a call to make sure the Roaming is set up before you go 🙂
Thanks, Leanne.
