by Goffin Contributor
Data roaming in France
I have a new £25 PAYG package with 5gb left on it. However, in France I can't login to Internet using data (works fine on WiFi). Calls and text work ok. I've checked the data settings and all seems fine there. Any idea?
Solution
Re: Data roaming in France
Tried that, too. Back in uk now, but I'll be going to Spain and France again in a couple of weeks and would like it to be working by then.
9 REPLIES 9
Hello there @Goffin.
Thanks for posting.
What device are you using?
Also what happens when you try and access data?
Thanks, Leanne.
I'm using Sony Experia. It worked fine in Latvia, but not Lithuania and now not France. When I switch data on absolutely nothing happens. I still have a signal with the R for roaming, but no data connection. I'm logged on with Orange France.
EE Employee
HI @Goffin
Please do try a manual network search and choose an alternative network carrier, does this help?
Many thanks,
Lee
I tried that, but no difference
EE Employee
Hi @Goffin
Please try and turn 4G off and resort down to 3G does this help?
Many thanks,
Lee
Solution
EE Employee
Hi @Goffin
You should not be facing any issues if your calls and texts are working fine, it maybe best to give us a call whilst roaming to have our technical team run some troubleshooting.
Many thanksm​​
Lee
Ok. Thanks. What number should I call for that?
EE Employee
Hi @Goffin
The relevant number can be found on our get in touch page.
Many thanks,
Lee
