by Witten30
New Member
Data roaming in Canada
I have 10gb of data when in the Uk on my plan but i am off to Canada for 3 weeks shortly.  will i need to add on further data usage?
Solution
Re: Data roaming in Canada
Hi there @Witten30
Welcome to the community.
3 weeks in Canada bet you can't wait 🙂
If you have a Max Plan started after 10 May 2017, you can also use your minutes, texts and up to 15GB of data within 53 destinations including Canada, Mexico, Australia, New Zealand and USA.
If you would like to benefit from these additional 5 countries, please get in touch with our mobile care team, to discuss options available for you.
Before you go text ROAMING to 150 to make sure roaming is set up for you.
Have a great time 🙂
Not if you have an EE Max Plan. Otherwise you would need to buy a Travel Data Pass as per https://ee.co.uk/help/add-ons-benefits-and-plans/call-or-going-abroad/roaming-costs/countries/canada .
Solution
Hi there @Witten30
Have a great time 🙂
by Ace Contributor
If you don't have a MAX plan, the Roam Further add-on is the best one you can get in my opinion.
