by dbr
Data Roaming Settings
I have Travel Data Pass add-on enabled for my visit to the USA.
My phone has a setting under Mobile Network Settings for Data Roaming which  has three options: Off, National roaming or International Roaming.
Do I need to change this setting?
by Brilliant Contributor
Re: Data Roaming Settings
You may need roaming on your account. This can be done by getting in contact with the CS team.
One may be along here shortly.
by dbr
According to myEE account online, I have roaming enabled.
I'm more concerned with the settings as I don't want it enabled if there are settings preventing it from functioning.
If you have Roaming enabled and a travel pass then it should all work just fine, You will need it set to International Roaming.
by dbr
Thanks bob Smiley Happy
I'll give this a go when I'm out there .....
