by tharper97
Cyprus roaming
Hi. I’m currently in Cyprus and unable to make any calls on two different iPhones (6s).
roaming is set to on and they were working at the start of the holiday.
Dial assist is switched on. I’ve tried turning that off and manually entering the number putting the internationaldialling codes in instead but it makes no difference. I have three bars with MTN.
Anyone got any ideas.
Many Thanks.
Tam
by Brilliant Contributor
Solution
Re: Cyprus roaming
Hello @tharper97
Thank you for posting on the Community today. Smiley Happy
I hope you're having a lovely time in Cyprus, it's one of my favourite places to visit. Smiley Happy
I travel to Cyprus at least once a year and I sometimes face the same problems you are currently experiencing. I usually manually roam onto Cyta-Voda and that normally fixes any problems that was occurring.
You can manually select a network by going to Settings > Mobile > Toggle the "Automatic" Slider to Off > Select Cyta-Voda.
I hope this helps. Smiley Very Happy
Re: Cyprus roaming
Hi @tharper97,
Welcome to the EE Community.
What happens when you try to make a call?
Do you hear a recorded message?
Are you able to receive calls?
Solution
Re: Cyprus roaming
Hello @tharper97
by tharper97
Re: Cyprus roaming
Hi. Yes. Spent some time on live chat with ee and this was the fix. MTN was the automatic selection for a provider here and changing it over manually to one of the other available ones resolved it. Many thanks for taking the time to post.
Cheers.
Recent solutions
