by film727 Valued Contributor
Valued Contributor
Currently abroad no network access to 3 available local networks.
Cannot receive or make calls while abroad. Phone shows no signal but can identify 3 available local networks. When I try to chose network it says No network access I'm on Orange pay as you go
14 REPLIES 14
by Brilliant Contributor
Re: Currently abroad no network access to 3 available local networks.
Which country are you in?
Do you have roaming enabled on your account?
Do you have credit?
EE Employee
Hi @film727 and welcome to the community.
Please can I get you to change your network settings to 2g/4g only to see if that helps.
Many thanks,
Lee
Valued Contributor
I'm in Bosnia, some credit available. I'm not sure if I have an online
account, isn't roaming enabled by default? I had used this sim and mobile abroad before
Read more
EE Employee
Hi @film727
Roaming is indeed active for pay as you go as default.
Are you aware if anyone else you are with is experiencing an issue?
Many thanks,
Lee
Valued Contributor
I have another phone with me, it's on 3 network and is roaming fine. Orange PAYG is able to detect 3 local networks but then shows no network access if I try to select one.
I have some credit on Orange but I last topped up a long time ago - is this an issue? Is there a customer number I can call without paying £1.50 a minute (Bosnia outside EU)?
Hello there @film727
Thanks for coming back to us.
When was the last time you used the Orange SIM?
Have you sent a text, used data or made a call recently?
Thanks, Leanne.
Valued Contributor
Orange Sim is in regular use in UK, so last use was last week.
Thanks for confirming @film727
What device are you using?
Thanks, Leanne.
Valued Contributor
Old Nokia 6303. It shows no signal bars wherever I take it, but when I select manual network search it finds 3 available networks. If I try to connect to any of those I get No network access message.
Thanks @film727
Are you able to try the SIM in another phone at all?
This is strange as all available networks should work fine for you.
Valued Contributor
I'm now in Croatia (EU member) and Orange SIM is roaming fine. Can it be that PAYG Orange SIM is not available for roaming in Bosnia?
EE Employee
Hi @film727
Im a bit confused on this one 🙂
I will certainly have a quick look into this for you.
Many thanks,
Lee
EE Employee
Hi @film727
Are you able to use data at all?
Many thanks,
Lee
by abenn1 Contributor
Sorry to butt in on this discussion, but I'm in the same predicament in Bangkok and can't for the life of me figure out a way to get in touch with Orange/EE.
My phone is Samsung Galaxy S5 with Orange PAYG which is used in UK regularly and has also been used many times in Bangkok on previous visits. It was topped up with £50 last week in preparation for this visit.
When I arrived yesterday morning my phone failed to register with a local network. In the past it has usually done this within 5 minutes of switching on. I can see about 10 available networks, and have tried to register manually and auromatically, but to no avail. Yesterday after about 3 hours I did get a welcome text from Orange setting out roaming costs, but my phone is still unable to register with the local networks.
How can I fix this please?
