by Firethrough Investigator
Currently aboard in USA, can't use text or calls
I get error code 34 when i try to text, and when I try to call it says my account isn't validated.
Many thanks
8 REPLIES 8
Re: Currently aboard in USA, can't use text or calls
@Firethrough   Did you enabled roaming on your account before leaving the UK
I realised I hadn't registered an account with ee online so I've just been doing that, it says roaming is enabled now, but I don't know what if it was before
@Firethrough  If you’ve just enabled it then it wasn’t and it can take up to 24 hours before your get a working signal on your device.   It also might be worth restarting the device a few times as it’s best to do this when you go abroad.
Thanks! If that doesn't work what would the next step be?
@Firethrough  You need to give it time first.  If it doesn’t enable then come back here and it can be looked into.  But you need to wait first.
EE Employee
Hi @Firethrough
As advised by @Chris_B it can take a little while to activate - sometimes up to 24 hours.
If it's still not working once that's passed pop back and let us know.
Also if you let us know if you're a personal or business customer.
Thanks - Karen. Smiley Happy
It's still not working, and I am a personal customer
EE Employee
Hi @Firethrough
Sorry to hear it's still not working.
I'll send you a Private Message with a link to the chat team.
Enjoy your time in the USA.
