by Kersh57
Cueta
I am visiting Cueta a Spanish enclave in Morocco. Can I use my EE package there?
by Ace Contributor
Re: Cueta
Hi @Kersh57 Welcome to the community. Ceuta should be regarded as part of the EU and therefore you can use your usual allowances (and up to 15GB data depending on what you have) when there. I'm having some issues trying to find a link to confirm that as it's always good to see it written down!
Check you have enabled roaming on your phone before you go though, text ROAMING to 150 now to be sure.
Re: Cueta
Hi @Kersh57.
As long as you can pick up a Spanish network your services will be included.
Please be aware if you are roaming near a border.
I hope you have a lovely time in Cueta.
Katie 🙂
