by Jacky3
Coverage in United States
I was advised to go on max plan so I could use my phone in the States. I seemed to be able to use internet for first few days but not now. Why has it stopped working?
EE Employee
Re: Coverage in United States
Hi @Jacky3 and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
iPhone: Go to Settings > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Android: Open the Settings menu >Tap More > Mobile Networks > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
by Jacky3
I looked at available mobile network operators. It says
T mobile
A T & T
When I click either of those it says
unable to connect try later.
It says the same when I click
Select automatically.
EE Employee
Hi @Jacky3
Thanks for trying this for us.
I have sent you a private message on here, so I can get some details from you.
Thanks,
Lee
