by Art011 Investigator
Connect to Network in Jamaica
Hello,
I'm currently abroad in Jamaica for two weeks my phone is not connecting to the local operator. I get an error message suggesting that my sim does not allow registration with any of the options. Flow being one of them.
Can anyone assist?
Solution
Re: Connect to Network in Jamaica
@XRaySpeX Thanks for your responses, all sorted now. I switched on roaming via  EE online account phone managememt. The functionality had been disabled. It stated it may take up to 24hr to mobilise.
Woke up in the morning and still no change on phone so I manually searched and registered the network via the phone as I had tried yesterday  and this time it worked!.
Thanks for advice RE not requiring to switch of data roaming I'll remember that next time.
@Art011: Did you activate roaming on your MyEE a/c before you left? Presumably not. Having a roaming allowance does not auto enable it. You may still be able to in your online a/c under Manage Devices. If not, you will need to call EE. Use the landline nos. in my sig.
Many thanks for your swift response. That could possibly be the issue I did call ee to disable my data to avoid unexpected charges whilst abroad as I've done before prior to travel  but didn't expect that to interfere with actual connectivity to the network operators.
I'll check whether I can activate via my ee as have no other means of calling ee except via my phone which has no network operator for calls.
If on EE, no need to disable data when abroad. You can't use data there without buying an add-on.
Are you on Orange or TMobile?
Solution
Thanks! You're welcome :)! Glad I could be of assistance & it is now sorted.
As well as setting Roaming ON in MyEE you may also have to allow Call Abroad & Premium Calls.
