by Skilled Contributor
Skilled Contributor
Confused and mixed message
Can you make it clearer what is happening here, its confusing. Its states roaming is enabled, then below states it may take up to 24 hours as your setting the phone up. Why would i see conflicking messages when ive been with you for over a year and have already used my phone abroad?
by Profile closed
Not applicable
Re: Confused and mixed message
Mine started saying that the other week as well.
It's just another section of My EE which doesn't seem to work properly.  I believe there was a small update of MyEE and every time EE roll out an update for one section of My EE, it seems to break another section!
Hi @leeuk
That looks unusual.
What happens when you text ROAMING to 150?
