Highlighted
by Investigator
Cant use phone at all in Greece?
Can’t use phone at all in Kos. No WiFi texts or phone calls. Anyone have a similar problem or solution? Thanks
Highlighted
Re: Cant use phone at all in Greece?
Hello there @Kisky123
Can you receive calls and texts?
Also, can you try and select a different network in the phone settings as below;
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Let me know how you get on.
Leanne 🙂
Highlighted
by Investigator
I’ve done all that. Nothing works.
Highlighted
by Investigator
It may be that I’m blocked from EE. I asked a couple of weeks ago to be restricted from making international calls within the U.K. as my child had accidentally made calls on my mobile. I don’t know if this has affected my settings. I can’t call EE though to check as it won’t let me call using WiFi
Highlighted
Hi @Kisky123
Thanks for coming back to me.
You can check your roaming status by logging into your My EE account online and go to Menu > Manage Device > Roaming Abroad > This will show as ticked if roaming is activated.
If you need any further support and you're a personal pay monthly customer log into your My EE on your phone's browser (not the app) or a computer.
Once you're logged in, a chat window will pop up when an advisor is available.
Thanks, Leanne.
Recent solutions
