by Mataliskova1 Investigator
Cant text or call in eu even though roaming is turned on
I am currently on holiday in Slovakia which is in the Eu.  I am unable to text or call even though I enabled roaming both on my ee account and on my phone. It says that i am connected to a network and I do have signal and i can use my data, but i am unable to call or text. I cant even text 150
Solution
Re: Cant text or call in eu even though roaming is turned on
Does it say International Calling is activated?
8 REPLIES 8
Did you activate roaming on your MyEE a/c before you left? Presumably not. Having a roaming allowance does not auto enable it. You may still be able to in your online a/c under Manage Devices. If not, you will need to call EE. Use the landline nos. in my sig.
I have enabled it under Ee under manage my devices and it says it was allowed that's why i am confused as to why it does not work.
Solution
EE Employee
Hi @Matliskova1 and welcome to the community.
So I can try and help, please may I get you to perform a manual network search and choose a network other than what you are on.
iPhone: Go to Settings > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want.
Android: Open the Settings menu >Tap More > Mobile Networks > Carrier and turn off Automatic. Wait until available networks appear, which might take two minutes. Tap the carrier that you want
Please, also can I get you to try and dial a friend or family member using the format of 00447********* and try using data.
Did this work?
Many thanks,
Lee
Thank you for this advice but unfortunately i did change the network and it still does not work . Every time i try to call a number it says that i am not allowed to dial that number. I have tried putting 0044 infront but it still does not work. My data also does not work and neither do my texts.
Thank you,  i turned it on and now it works.
Thanks! You're welcome :)! Glad I could be of assistance & it is now sorted.
EE Employee
Brilliant @Mataliskova1
Milujem Slovensko 🙂
Many thanks,
Lee
