by Hugoabrutat
Cant send texts from abroad although i can recieve them, i get error code 69
7 REPLIES 7
Re: Cant send texts from abroad although i can recieve them, i get error code 69
Hi @Hugoabrutat
Welcome to the EE Community, thanks for posting your question here. 🙂
Are you able to make calls?
Please try this troubleshooting:-
Try re-booting your device
Try turning 4G off in ‘settings’
Perform a manual network search:-
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Please let me know if any of that works.
by Hugoabrutat
I tried all 3, no change, and i am able to make calls
Hi @Hugoabrutat,
Are your numbers stored in the international format? (+44)
What type of phone are you using?
Is it a pay as you go or pay monthly plan?
by Hugoabrutat
Numbers are stored as international, im using a nexus 6p on pay as you go
Thanks @Hugoabrutat
Do you have sufficient credit/allowance to send the text?
Was it working in the UK?
by Hugoabrutat
It was working fine in uk, and i have unlimited texts
Hi @Hugoabrutat,
Which country are you in?
