Highlighted
New Member
Cant make calls or send texts since changing plan
Have just changed from pay as you go to pay monthly. Now i cannot send texts or make calls. However i can recieve them and data works fine. Im in germany and wonder if that has had an effect on the change of plan?
Highlighted
Re: Cant make calls or send texts since changing plan
@Doybe536 have you enable call abroad and premium rate numbers from within your online account?
Highlighted
Hi @Doybe536,
That's great advice from @Chris_B. You can find your roaming settings by selecting Manage device from the menu in My EE.
Hope this helps.
