by Ziggy12
Cant call the uk from greece all is set up and ee was called before hand
Called ee before leaving for greece and said all was set up to call uk, all my settings online are switched to allow and still cant make a call to the uk even with the right area code. Can call greek numbers but no uk very frustrating cant even call ee!
by Ace Contributor
Re: Cant call the uk from greece all is set up and ee was called before hand
HI,
@Ziggy12
Have you try with 00447****or +44***** before number to call back UK?
When you try call on UK number what prompt message you get?
by Ziggy12
d Re: Cant call the uk from greece all is set up and ee was called before hand
Hi there Ive tried that but it says unauthorised selection no matter what i do even when calling ee
Hello there @Ziggy12
Thanks for coming here.
Do you get an error message when you call the UK?
Can you send texts?
Thanks, Leanne 🙂
